Go Back  DoItYourself.com Community Forums > Garden and Outdoor Center > Pools, Spas and Hot Tubs
Reload this Page >
How to relace 3 way valve while pool is operational
Old 07-25-05, 10:51 AM
rock8822
Exclamation How to relace 3 way valve while pool is operational
My 3 way main valve has broken and I am trying to find a solution to stop the water flow while I change it. The pool is an 18' above ground and is full of water. The handle broke on the 3 way valve and I can't fix it so I have to replace the entire valve. What can I do?
Old 07-25-05, 08:45 PM
put plugs in the return fittings and also the skimmer, and while your at it install shutoff valves after the heater [ if you have one] if not after the filter in order to service your equipment next time.
steve
Old 07-25-05, 10:35 PM
rock8822
Thanks Stevie3x but there's one more thing...
Steve, the plugs sound good but my main concern is how to dismantle the 3way valve without water pouring out everywhere while I install the plugs.
At the risk of sounding really dumb, can you suggest an order of things and how I might proceed to avoid major water loss?
PS I have no heater.
Old 07-26-05, 06:27 AM
rock8822
Thanks Steve - one more thing
steve
My problem is being able to control or stop the water flow to even put on these plugs. Can you suggest an order of things or a way to proceed?
PS - I don't have a heater
Old 07-28-05, 08:29 PM
1. shut off pump and also circuit breaker, so you are absolute sure the pump will come on.
2. put plugs in all the return fittings .
3. put a plug in the skimmer .
4. if you have any other fittings , where pipes are connected to your pool for what ever reason put plugs in them also.
5. now you can cut pipes, take the valve apart , whatever as no water can flow to your severed piped , providing you have all fittings plugged.
6. after making the repairs, reemove all of your plugs , turn your breaker back on and presto your good to go.
steve
Old 07-30-05, 11:38 PM
rock8822
Thanks again Steve
Thanks for the step by step Steve, that's what I needed. So I guess that either way I should expect some degree of water flow as I unscrew and plug pipes during the process, right?
My water is so green now, after not being able to use the filter that I can't even see to get to the bottom of the pool to plug the drain!
I'm getting frustrated and discouraged.
