How do I fix cracks in hot tub?
brother got a tub and flipped it over to replace wood underneath but has hairline cracks in the bottom which leak...any ideas or products to use that will fix this problem...? any info would be great... thanx, Saldog
if its plastic, fiberglass , acrylic, rovel, etc.... i would use resin and glass cloth just like a boat repair, color can be added in the resin when mixing,
be sure to drill a small hole at each end of each crack so it will not continue to crack.
steve
steve
