above ground Pool heater installation
pool heater
one thing to remember when piping up your heater is you must pull out of your heater. Meaning the suction side of the pump must pull out of your pool through the pump out the discharge into the heater out the heater and return to the pool, keeping the flow. But check on wich model heater/heat exchanger you have name brand some differ. you can find instruction's on internet. Example Raypak is a gas heater brand.
