Building a hot tub from the ground up
I just got my hands on a huge hot tub (just the tub and pipes) and I want to build it up from scratch. I dont know anything about hot tub's innards, but I'm going to learn. From what I have read, it looks like I need a blower, heater, 2 speed pump and filter. Now this tub is 7' x 7' so I figure I should probably use 240V instead of 120V. I also figure that I should probably get at least 2 horsepower blower and pump. And I'm probably going to go with a 100,000 BTU Natural Gas heater. Anyone with some knowledge have any advice?
Here is a site for parts that I found. They seem to have good prices on their items.
http://www.spareplacementparts.com/
I also recommend if you know the manufacturer of the tub then go to their site and see if you can get some info on what was in the original tub.
I don't know how the gas fired heaters work but if you go electric you can get a equipment pack that has all the controls with heater in one unit.
Good luck. This sounds like a fun project.
Originally Posted by NewToSpas
Thanks for the reply. Do you have any advice on the number of pumps and HP of each?
I have 1 - 4.5 hp pump with 12 jets. My tub is 450 gallons.
You might want to look at some tubs that are set up like yours to get a better idea of how to set it up. Also keep in mind that high horse power is not the important part. You don't want a system that is so powerfull that it blows you out of the seat.
Personally, I wouldn't bother with the blower. I had one on a tub I had a long time ago and it was virtually useless. When using it with cold air temps, the air coming out was too cold, so we hardly ever used it. Mass flow would be such that the warm air in the cabinet is consumed in just a matter of seconds, then you're drawing cold ambient air into your cabinet through the blower.
Well designed jets with selectable air mixing would be the way to go. My current tub has them and they produce sufficient "massage power" for our needs.
As to the number of pumps, yea it depends on the number of jets and the flow you're trying to achieve. My old tub had one pump, but only about a dozen jets. My current tub has two pumps, but I think 54 jets.
100,000 BTU gas heater would overkill, I believe. What do you want to do, keep the water just above freezing and then heat it up in just a few minutes? Pool heat pumps are only 100,000 BTU's and pool gas heaters are only up to 400,000 BTU (and we're talking for 30K - 40K gallons or so).
Good luck.
Good luck.
