filter pump position diagram
Old 12-17-05, 09:25 AM
wilkie
any one know where i can get a diagram of a typical pump filter set up
any help would be appreciated
Regards Wilkie
Old 12-19-05, 07:06 AM
I may have totally misunderstood your question here ... are you trying to install/replace a pump and filter??
your *best* "diagram" is not a downloadable one ....
go see some filtration systems of your friends/family if they have pools ... or a neighbors ---
after you look at about half a dozen, you'll begin to realize that each set up is overall, the same, but different in some (miniscule) ways ...
if you're replacing the pump and filter --- you're pretty much at the limits of where the pipes are coming out of the ground (and to save you the trouble of turning a simple little 2 hour ordeal into an all day project --- respect these limits)
I know this prolly didn't answer your question --- but the point I'm trying to make to you is that you don't *need* a diagram
