Drain Pool Water?
Drain Pool Water?
I had my water sample checked last weekend with a local pool supplies store. The rep asked how old was my pool and if I have drained it? His logic was that water gets tired. Is that a true statement?
Are you (not you, but the sales rep at your local store) serious??
I would (seriously) go back to the owner of that store and suggest to them that they start doing drug testing on their employees
what were your sample results? and just in case I've missed something, explained what he meant by "water getting tired" --- do the molecules max out their 401(k)s or something and retire??
good luck ---
good luck ---
Water Tired?
Thanks for the reply. Water sample results were fine. He added that water should be drained after two years. It's difficult to find a reputable pool store. The other place I used to go always find something wrong (I need this and that). That's why I'm back to my test kit.
Water
Did the "very helpful" clerk test the TDS (Total disolved Solids), High TDS is one of the only reasons to drain pool water but chances are if the pool is only 2 years old the TDS should be fine. If you ever find a good pool store you should post it. (I won't hold my breath)
tired water
WOW ! I have been in the pool business for over 25 years and this is a first for me, "tired water". Maybe it was a "lazy sales person". What is actually wrong with the pool water, is it cloudy? green? etc. If it looks ok and the chlorine, ph, and total alk all ok then i wouldnt worry. just keep those 3 things perfect and you should have no worries.
On the other hand, depending on your water rates, it can be cheaper if the water gets badly out of balance to just drain it and refill it will tap water which is closer to the chemical levels you need.
It might cost $15 to refill a pool, or $150 in chemicals to get it to what tap water would be at.
Empty pool floating up and away
Someone sent me this picture of a pool that was drained completely dry, evidently during the raining season when the water table was high.
http://home.comcast.net/%7Ekelsi.detweiler/floatingpool.html
I can only imagine how I would feel if I took that guys advice without thinking and then ended up with this nightmare.
I wonder if this happens frequently, has anyone else ever seen an empty pool "float" up out of the ground like this?
Even a septic tank will float if it is empty.
If it's a concern, drain the pool only half-1/3 of the way empty then refill.
