Hot Tub Flexible tube repair
Old 12-31-05, 02:32 PM
Spa man
Question Hot Tub Flexible tube repair
Does anyone know how to replace one section of 1-1/2 flex tubing on a hot tub that is glued in with PVC cement? Do I have to replace all the tubing?
Thanx,
Nick
Old 01-08-06, 05:34 PM
Tubing
If the glue joints are Ok then you cna replace just a section of the pipe. You will need a piece of pipe and 2 -
1.5" Couplings to do the job. Use a hacksaw to cut out the unwanted section and glue a copling on the ends of the pipe you are keeping then glue the repalcement pipe in place. Make sure you use a heavy body PVC glue not just clear glue. It will give a better bond and last longer.
