can i
can i
i want to drain my pool and resurface how hard is this and does anyone know where i can find a manual also does anyone know where i can find or what stuff i use thanks in advance
This isn't usually something that people do themseleves. You may want to consult a local replastering company to do this job for you. I don't know of any guides that would help you do this. Most GOOD pool stores should be able to get the supplies for you.
Cruel Neo
I heard someone say one time "if ya need an instruction manual --- you probably shouldn't be doing it in the first place"
I hate that saying. I really do. But in the case of pool plastering --- it certainly applies.
It is intense --- and requires about 4-6 EXPERIENCED workers. There's very little time for learning on the job. Just watching a plaster job would be enough to make you run, not walk, but run to your nearest Yellow Pages.
As for the preliminary/prep work -- a DIY-er could probably handle this after they knew what they were doing. But the money saved here is probably not worth it. (I do plaster prep work for a living and I'm not sure if the money MADE is worth it, LOL)
In regards to draining your pool --- certain procedures must be taken to issues like hydrostatic pressure. The consequences for negligence or inexperience here is enough to make you shudder.
GOOD LUCK!
GOOD LUCK!
