Draining a Hot Tub
Old 04-02-06, 02:10 PM
C
Draining a Hot Tub
I just bought a house that has a hot tub that's really not in the greatest condition. I would like to remove it but I know nothing about hot tubs.
First what's the best way to drain it, is there a drain plug somewhere?
Also do I need an electrician to handle the wiring?
Thanks
Old 04-08-06, 10:30 PM
Josh2006
Is the tub in a wood deck, freestanding, etc?
Many tubs have drains. If you can answer the question above I will try to help you locate the drain.
It's always the safest idea to have an electrician to wire and un-wire hot tubs. Remember many hot tubs are wired at 220v...
Josh
Old 04-09-06, 07:02 AM
D
is it indoors or outdoors?
is it an actual hot tub --- or a spa (portable, permanent)
more details
Old 04-09-06, 09:58 AM
Josh2006
The words hot tubs and spas are generally both used to describe both jetted bath tubs and portable/in-ground relaxation tubs.
Old 04-09-06, 06:47 PM
R
Draining Hot Tub
You need a electrician to unwire & There should be a drain in plumbing around Pump. If not you will have to cut pipes or suck out with wet dry vac.
