Spa pump bearing noise
Old 04-03-06, 05:03 PM
W
I have a Leisure Bay 19200S2 spa. Its making a whining noise when the pump is running which I suspect to be a bearing going out. I believe there are bearing in the wet end as well as the pump motor itself, right? Assuming so, how can I best determine which part needs to be replaced?
The pump is listed on the spec sheet as a 1 x3 HP, 2 speed, 56 frame. Its 220v. Not sure what brand it is, panels not removed yet. Just trying to get an idea of what I'm up against before I start taking it apart.
Thanks for any suggestions.
Tom
Old 04-04-06, 05:39 AM
W
Well, it locked up last night. Any suggestions on best place to get a new one?
