Iron in water
I currently have a very small (1300 gal) pool, but am looking at putting in a larger 25,000+ soon. My problem is, I filled the small pool up using our well water and it is full of iron (very red/brown). I can't even see down past a foot. I have shocked it a couple of times and it is getting better, but at this rate it will not be clean until the fall. What is the best way to clear it up? If I build a large pool, will I need to have water brought in?
Thanks in advance!!
Thanks in advance!!
do you get that in your home also? sounds like the well pump is pulling silt.
if its not then try a chealeating agent.
this is a chem used to remove metals in pool water.
I have very heavy Iron here at my well at my home, and just filled an 18,000 pool, shocked it and after 1 day was clear, still cleaning red from the cartrage filter at each cleaning...something is wrong if your is still cloudy, run the pump 24/7 until it clears
my water is so bad we dont drink it, we do wash and flush with it, but turns a shower curtain red in about 4 days, water system will cost about $ 4-5000, just have to deal with it right now, had it tested, no bacteria, just heavy iron concentration
found a cleaner called the works at the dollar store, really helps wit hthe iron stains, but I would not put it in the pool
