liner problem again
liner problem again
I had to install a new liner because the old one was 10 years old and kept coming off the bead receiver. New liner was great for 3 weeks now is also popping off I measured the waterline around the pool and there is an inch or so difference in places Would this cause the liner to pop off It is a beaded liner. This is making me crazy. Is it possible after 10 years there is just not enough sand on bottom. How deep should the sand be and how high and out should the cove be, Plese help my kids are driving me crazy. Cliff
Sounds like you got the wrong size liner. Do you have an above ground or inground pool? If ag pool, you could try draining pool and adding more sand to bottom. What kind of cove do you have? Sand? Might try making it a little bigger to keep liner from sinking into corners.
