Grandee hot springs hot tub 1995
Old 07-04-07, 06:20 PM
L
Question Grandee hot springs hot tub 1995
We moved into a house with a 1995 grandee hot tub. There is a leak on the upper back left corner opposite side of the control panels. We were able to get the tub lifted to start removing the foam underneath. Anyone have an idea of how we can test where the leak is coming from and how to fix it? Also, There is still foam stuck on the pipes. We tried gasoline and acetone already. Any other suggestions?
Old 07-08-07, 08:56 AM
D
urethane foam is best removed with a wire wheel on your choice of power tools.Almost nothing will remove it chemically.
