A.O Smith pool pump question!
Old 07-24-07, 05:50 AM
E
Hello all again i could use some help from you pros.. I have a two year old A.O Smith 1.5 hp pool pump that works very well but i have recently noticed that after about two or three hours of pumping it trips the breaker and i have to restart it again. It is connected to a 15 amp gfc breaker which is not too old. Could the pump be overheating? Any help will be appreciated and thanks for looking.
Old 07-24-07, 12:46 PM
todrut's Avatar
It could be the breaker, pumps do not need to be on gfci only lights must be. I would put it on a 20amp regular breaker, should solve problem.
Old 07-24-07, 05:45 PM
HotxxxxxxxOKC's Avatar
Received 1 Upvote on 1 Post
Hopefully the wiring is 12awg and not 14.
Old 07-25-07, 06:00 AM
E
Thanks guys the wires are good but i will try the breaker change. Thanks again
Old 07-25-07, 07:14 AM
mattison's Avatar
When you say the wires are good are you sayin they are 12g ? Also in my area the pool pump service must be protected by a gfi. I opted not to go with the breaker type and used a gfi recepticle to protect it and the inspector was happy.
Old 07-25-07, 07:43 AM
todrut's Avatar
Really? Its code to have a gfi on the pump? It is not in TN and several other states I've worked in.
Elacesar, make sure to check local codes.
Old 07-27-07, 05:08 PM
E
a
thanks alot guys for the help..
