Pool Waste
Pool Waste
I am getting tired of dragging the blue waste hose to the street whenever i have to take water out or backwash. I was thinking of running pvc under the ground from the waste pipe to the street and cut a hole in the curb. Should i run 1 1/2 inch or 2 inch pipe. All pool plumbing is 1 1/2 pipe
Is this Plausable?
Any tips to get pvc under sidewalk?
Any tips how i can cut the hole in the curb without damaging it too bad?
Is this Plausable?
Depends on how far the run is and what hp your pump is and filter size. I would run in 2" just to be safe. You can rent a concrete saw or core drill from national hardware store. That would be what I would do.
How to get the pipe under the sidewalk?
This forum has a discussion about it.
http://forums2.gardenweb.com/forums/...341731539.html
Basically, you use a pressure washer or make one out of a length of 3/4" pvc pipe, cap the end, drill a hole in the cap. On the other end attach a fitting that will hook up to your garden hose. Dig a hole beside the sidewalk and use the pressure washer to tunnel under the sidewalk. Very messy. Use eye protection.
