Pool Leaking--Fix or Fill?
Old 08-24-07, 09:40 AM
Question Pool Leaking--Fix or Fill?
I have a 15,000 gallon in-ground pool. Water is leaking out down to at least the skimmer level. I see no cracks in the pool. The leak could be in the skimmer or the piping to and from the pool. I have not yet been able to determine the source of the leak using drops of pH tester.
Am I likely to be better off cost-wise to repair the pool or to have it filled in?? Approximately, what does it cost to have a 15,000 gallon pool filled in?
Old 08-24-07, 10:11 AM
todrut's Avatar
Can't really answer this question because of the diffence in what it would cost locally to have loads of dirt brought in. I would contact a local dirt hauler.
Fixing could cost from nothing to hundreds of dollars.
