Pool closing
Old 09-16-07, 06:47 AM
Red face Pool closing
Hi, This is the first time I've closed a pool and, as such, am a bit of a novice. I have an inground pool with a 1.5hp pump and sand filter. As I'll need to drop the water level prior to closing, is it possible to unhook the pump from the filter and use this to drain the pool level, rather than buy a separate jet pump for the job?
Thanks
Old 09-16-07, 07:15 AM
todrut's Avatar
You can drain pool by using your pump and filter, just put multi port valve on waste. Unhooking pump will not drain unless its below water level.
