OK to use pump to pump pool antifreeze?
I need to pump some of the pool antifreeze into my lines. It contains ethyl alcohol and propylene glycol. The pump I was going to use is a small electric water pump that has connectors for a hose on inlet and outlet. It says not to pump highly flammable liquids. I didn't know if the antifreeze would be considered highly flammable as it does have ethyl alcohol. Of note, the pump was purchased to pump out the home heating oil from my old tank. The company that supplies my oil said that it is ok to pump home heating oil (which is essentially diesel fuel) because it is not going to ignite like gasoline would. anyone know about pool antifreeze?
you're asking for trouble if you put car antifreeze in a pool. There is antifreeze made just for pools, your local pool store will have it. Don't take chances, make sure to blow the lines out before adding antifreeze.
this is pool antifreeze! I bought it at pool place and it has instructions for pool use. It is not at all like car antifreeze which is ethylene glycol (which is traditional antifreeze) or pure propylene glycol (new "safe" antifreeze) This is propylene glycol AND ethyl alcohol mixture. it is much thinner in viscosity than car antifreeze and very light pink tint. It is peppermint scented.
Well I was able to find website of the company that makes the pool antifreeze I bought-(www.camco.net). They have two types, one is propylene glycol base and the other is alcohol base (with propylene glycol in it also) The MSDS were not available so I don't know the concentrations or flash point. The place were I bought it didn't have the other kind. It does say combustible on the container so I am not sure if safe to pump it or not. I am sure they can email me MSDS. what would be safe flash point to be able to pump it.
