Aquarite interface questions
Hi,
I have an Aquarite chlorine generator and would like to interface to my home automation system. I see some connections in the box but don't know if they are Rs-232, 485, current-loop, etc?
I just need the correct connections and I can write the software I need to talk to it.
Any help appreciated and thanks in advance.
Gerry
Gerry
Optional Goldline, Pentair and Polaris controls:
The Goldline, Pentair and Polaris controls use a 4 wire connection to communicate to the
Aqua Rite and can be wired up to 500' apart. Any outdoor rated 4 conductor cable can
be used. Refer to each manufacturer's instructions and the wiring diagrams below for
proper wiring connection to the Aqua Rite. NOTE: There must be only 1 "primary" unit.
All other Aqua Rite units must be configured as "secondary".
Input power for use with Goldline, Pentair and Polaris
controls:
Wire the Aqua Rite® DIRECTLY to 120/240VAC power (not through timer or relay).
Goldline - Attach wires to proper screw terminals as shown below.
Pentair - Attach wires to opposite numbered screw terminals as shown below. Note
that the colors marked on the Pentair PCB do not match the Aqua Rite.
http://www.haywardnet.com/products/m.../Manual193.pdf
controls:
Thanks for the info. I did find that info in the manual, however. What I need to know about those 4 wires that connect to different controllers is the function of each. Is it RS-232 or 485 or some other signaling protocol and if so, which one is the transmit, receive, etc. What I want to do if possible, is go right from the aquarite generator to my PC. I would be happy with just being able to read the display remotely. I'm thinking that that info could be hard to get.
Thanks again.
Thanks again.
Great! So now one should be xmit, one receive, one signal ground, and one chassis ground, correct? There are 4 wire positions, so now the BIG question: which one is which?
Thanks.
Gerry
Thanks.
Gerry
Thanks. I guess I'll have to contact them.
Also, I'm thinking that it may not be RS-232 since they say the units can be 500' apart. I believe 500' exceeds the specs of RS-232. I'm guessing 485?
Thanks again for all your help. I'll let you know what happens...
Gerry
Gerry
