Laars LX Temperature Control
I have a Laars LX Pool heater which has an LED Temperature Control Panel. It went out once previously and so I replaced it at a cost of about $ 500.00. It has gone out again and I hate to spend another $ 500.00 on this LED panel. Does anyone know where I could send it to be repaired? Has anyone had a similar problem and maybe knows what is casuing it to go out?
before you go off the deep end, have you checked the voltage, to the transformer ? if line voltage is ok either 120 or0240 vac check secondary voltage 27 vac also the fuse,
& / or fuseable link
steve
steve
