hot tub breaker overheating/tripping
Hi there, please help!!!! Every time we turn on the heater for our hot tub the breaker unit (called a gfci unit??) gets very hot on the right side and trips out. It works for 3 minutes each time before tripping out, if we leave it for a few minutes before turning the heater back on it lasts slightly longer. I do not think the problem is related to the heater itself as this was replaced just 2 months ago. We did notice that the blue grounding wire leaving the breaker was damaged (blackened and melted), so we cut away the damaged piece and secured it back into the unit. We have checked all other wires incase they are loose or damaged, but they are fine Any suggestions as to why it is getting so hot and tripping????
Thanks
Thanks
It could be a bad heater... been there, done that, in less than 2 months :-)
Could also be a bad breaker, or could be you didn't cut out enough wire (even though the wire LOOKS good, it could still be damaged and putting out some resistance).
Have you tested the amp draw through the wire/system? That could tell a lot.
Dr Spa, thanks so much for taking the time to reply. I am a bit of a novice to this sorry, can I check the amp draw going through the wire/system myself or is this something I will need an electrician to do?
All you need is an Amp meter. Radio Shack sells a combination volt/amp meter for around $20. The amp meter just clips around one wire and gives a reading when the power is on and the spa running (it's a bit confusing to read the meter, be sure to read the instructions).
I have spoken with the supplier of my hot tub and he is going to send me a new breaker unit and if that does not work a different type of heater. I will let you know what the problem is hen I find out for future reference. Thanks for all your help. Lou
