Go Back  DoItYourself.com Community Forums > Garden and Outdoor Center > Pools, Spas and Hot Tubs
Reload this Page >
Laars LX-400 heater with Air Flow SW error
Old 04-10-08, 07:53 AM
I have a Laars LX-400 pool heater with an 'Air Flow SW' error message. I have replaced the blower pressure switch to no avail. Any other suggestions? When the heater is turned on, it hums as if it is trying to start, but the blower does not come on, and after a few minutes the error message pops up.
Old 04-10-08, 06:58 PM
todrut's Avatar
If it is humming and the fan does not come on, sounds like it is the blower.
Old 06-04-09, 05:30 AM
E
Air Flow SW error - blower starts and stops
I have a similar heater but the blower actually starts, then stops, then starts then stops. The blower stays on betwen 2 -10 seconds each time. This happens between 4-6 times before I get the Air Flow SW error. I have checked the air tube and it is fine. What could be the problem with this.
Old 06-05-09, 06:52 AM
todrut's Avatar
I have found fan blockages a few times, wasp nests and mouse nests. You can remove fan and check.
