moving pool filter
Old 04-20-08, 08:27 AM
moving pool filter
I have an inground pool and the filter is on the corner of my patio and is an eyesore. i was thinking of moving it about 30' behind some bushes. My question is this: will this added distance have an effect on filtering ability? Also, if i add 1-2 90degree turns will this be ok?
thanks
birch
Old 04-20-08, 09:35 AM
todrut's Avatar
There is no problem doing what you want to do. Won't hurt anything.
Old 04-20-08, 10:04 AM
you are actually adding 60 ft. of pipe 30 ft. to the filter & 30 ft. back , each 2 " 90 adds the equivelant of another 8 ft. this is refered to as resistance to flow, in simple terms you would now have more resistance to your waters flow, more strain on your pump ,
my suggestion increase the size of your pipe from 2 inch to 21/2 inch , also use 2 1/2 inch 90 , I realize you have 2 inch at your filter , that can't be helped , just remember to transition to 2 1/2 inch as soon as feaseable
steve
Old 04-20-08, 10:24 AM
I get the idea behind changing to 2 1/2" pipe, but there will still be about 10' of pipe below concrete. Is it still worth thanging the pipe size leading from the filter to this section or is it a waste since that section will still be 2"?
thanks for the replies
Old 04-20-08, 08:35 PM
change as much as you can , without tearing up the deck
steve
Old 04-22-11, 04:05 PM
Moving pool filter
Does anyone have a suggestion for a good source regarding step by step instructions on how to move a pool filtration system about 30 feet?
Old 04-22-11, 05:03 PM
Hey,
As you can see, I did the same thing a few years ago. Basically ran PVC and tried to avoid 90 degree angles. I used a few 45 instead. Worked perfectly. No effect on filter even with the extra distance.
Hope this helps!
