Replacing the sand.
Old 05-08-08, 08:09 AM
mattison's Avatar
Replacing the sand.
What type of sand should I be using in my above ground pool sand filter ?
I bought play sand since it's so clean but it seems to be awfully fine and upon start up I've got a good amount of sand in the bottom of the pool now. Is that just due to new sand or do I need to use a different type ??
Old 05-08-08, 06:06 PM
todrut's Avatar
Some play sand will work but some won't. When changing sand you MUST fill tank half with water before adding sand. If this wasn't done you probably broke a lateral. I would remove sand inspect all laterals and hub closely. If all looks good put sand .45 - .55 mm rough not smooth back in it. Start filter on backwash to clean sand, then rinse, then filter...This should do it...
Old 05-08-08, 06:24 PM
follow your manufactures recommendation, if you don't have an owners manual, your local pool store should, write down any specs that may be on the filter & ? or take a picture your pool supply store should be able to figure it out, most sand filters take up to 300 lbs. of #20 silica sand
steve
Old 05-10-08, 09:15 AM
mattison's Avatar
Thanks guys. You're the best. I'll check all like said and change the sand.
