Hayward HD100ID1 ignition problem?????
Old 05-08-08, 06:28 PM
F
I see that you have helped a vew people on the Hayard HD100ID1 - Propane. I resently installed on my new hottub. I have electrical correct. When I turn the thermistat the fan starts - 5 sec. later hear the ignitor, cycles 3 times the stops. I'm pretty sure that the problem is gas flow or pressure. It is connected to a small propane tank with a 10 psi regulator. From the research i've done - that would equal about 11" W.C. - which is in range. Any suggestions????????
Old 05-08-08, 06:50 PM
todrut's Avatar
When you say small tank, how small? If it is a gas grill tank it will not work. Heater is 100,000btu and grills 20,000 - 40,000 most of them.
Old 05-08-08, 06:55 PM
F
It is about 2 times that size. Can't remember exacts on specs of tank.
Old 05-08-08, 07:04 PM
Todrut is correct, actually the size of the piping from the tank to the heater is more critical , you may have enough pressure , however what you may be lacking is volume.
steve
Old 05-08-08, 07:07 PM
F
I saw in the book about the pipe sizes and that is cool - 1/2 inch pipe tank about 15 feet from heater. What size would the tank need to be?
Old 05-08-08, 07:08 PM
todrut's Avatar
Too small, it takes a much bigger tank to be able to change from liquid to gas and feed heater. A 75 - 100 gal tank be work.
Old 05-08-08, 07:11 PM
F
Cool - Thanks guys!!!! That's why we go to the experts.
Old 05-10-08, 12:11 PM
H
In addition to the tank size you have a serious issue with your pressure. 10PSI is way too much pressure. 11 inches w.c. is approx 1/2 psi.
In the owners manual it has two different set ups for the gas piping. There is a single stage system which utilizes 11 inches wc right from the tank and a two stage system which utilizes 10 psi from the tank to a second stage regulator which will drop it down to 11 inches w.c.
There is likely a maximum inlet pressure on the spec plate of the heater which should be 13 inches w.c. Anything more than that can damage the gas control valve and void warranty.
