Robotic Pool Cleaner Issue
Hello,
I have a Dolphin Diagnostic Robotic pool cleaner and it seems to really like the deep end of my pool. I have an 18' x 36' inground pool. It cleans the heck out of my deep end. I start it in the shallow end, and does OK for about a half an hour, going in a random pattern around the pool. After that, it pretty much stays in the deep end, going back and forth from side to side. Anyone have any ideas why and what I can do to fix this?
Thanks so much.
Thanks so much.
Dolphin
Make sure the tube handle/float is locked diagonally and switch it every few weeks so it can change patterns. It should always be diagonal not straight across body of unit. Also make sure cord is floating and your returns are aiming toward the surface moving the water clockwise if possible. Make sure the bag is clean and installed right with the two black keepers over frame. Hope this helps! Brian
