H250 Help?
Old 05-27-08, 09:46 AM
H250 Help?
Maybe someone could help me as well? I have a Hayward H250 with electronic ignition. I just opend the pool last weekend. I start up the heater, it fires up, and then shuts down after 15 secs to 1 minute. It then gives me the "IF" message. Any ideas?
Old 05-27-08, 11:13 AM
todrut's Avatar
More than likely the heater needs to be cleaned out.
Old 05-27-08, 03:35 PM
An IF code should be ignition failure. To be sure there is likely a code chart on the heater somewhere.
If it is an ignition failure, you need to verify gas is getting through the gas control valve.
Old 05-27-08, 06:59 PM
todrut's Avatar
IF is ignition failure however it is lighting then shutting down, it is probably dirty heat exchanger, needs to be taken top off and sprayed out.
