Hot Springs Bengal Spa Leaks
I recently bought a spa that is a 2001 model. No evidence of leakage when on site. I moved to my home and leveled it and filled with water to find a leak the next mmorning. I removed the side panels to discover mold and mildew behind it. I dug out some of the foam to discover it is soaked. I can see that it appears the leak is from the corner seat area, but I do not know how to remove the corner exterior panel. No other problems noted.
After repairs can I use the expanding foam and let it cure then scrape it off so the exterior panels fit back properly?
Thanks,
Kevin
Thanks,
Kevin
Update!
I removed the side panel and started removing the wet foam lining and found the leak. There is a multi port distribution fitting that takes the 2" main line and reduces it to 4 1/2" lines. One of those lines sprung a leak at the "udder." At least that is what I am told.
Any ideas on how to repair the leak.
Thanks,
Kevin
Thanks,
Kevin
