New pool, need mtce tips
Received 0 Votes
OK I got the pool installed and a week and half later we finnaly got the filter running. ( small traces of green)
I figured out I have 3,253 gallons of water (12' round).
I need to shock the pool. The package says it has no chlorine in the shock. can I add chlorine at the same time?
How long should I run the filter?
How critical is the measurements of chlorine and chemicals? do I have to be exact to the smallest increment or can it be "close"?
Thanks in advance
Dan NJ
Thanks in advance
Dan NJ
Close is ok, but keep ph pretty close. I would use a 1/2 lb of chlorine shock to kill algea and bacteria(you'll see BIG difference within 4 hours). Make sure you have chlorine tabs in pool by floater or auto chlorinator. After 2 days add the other 1/2 lb shock. Run the filter constantly while clearing up, after clear it is ok to run 12 hrs a day during the sunny part of day.
