Moving a Hot Tub
Old 06-01-08, 09:23 AM
Moving a Hot Tub
We have a hot tub that needs to be lifted 18" off the ground and moved onto a paver patio. Any suggestions on how to lift and move it?
Old 06-01-08, 10:11 AM
Gunguy45's Avatar
Super Moderator
Drain it, disconnect all the electric,get 6-8 friends, lift it up into position.
If its not in great shape framewise, lift one side, slide some 2 x 4's or 2 x 6's under it until you have 3 or 4 equally spaced, then use that to lift it.
It's not that hard, the spa probably only weighs 500-600 lbs, it's just a bit awkward.
