Amount of water flow in a 1.5" pipe
Old 06-03-08, 09:21 AM
Hi There.
I was wandering how much water can go through a 1.5" pipe.
We have an inground pool with a 1.5hp pump and 1.5" pipes. My intentation was to hook another 1.5 hp pump for a solar system I plan to build. I would hook the second pump on the same input line as the filter pump for the solar system. But I don't know if there is enough water flow through that size of hose. Can the skimer deals with this amount of water?
Thanks for your thoughts
Old 06-04-08, 07:13 PM
if this is a normal type swimming pool pump, hayward super 2
sta-rite dura glass, or pentair whisperflow , the answer is
no.
Old 06-05-08, 08:20 AM
Thanks Stevie, that's what I thought. Too bad the installers didn't put a 2.0" pipe as this is what was recommended from the pump manufacturer.
Well the wife will have to endure to black pipes running to the pool.
Old 06-05-08, 05:48 PM
I apologise for not giving you a more, complete answer, if indeed you have one of those model pumps I listed, they have enough , power, flow, to do this dual job, as long as the run to the panels is not over 80 ft. then up the roof of a one story , the pipes will need to be a minimum of 2 " youll need a plumbing diagrapham & an automatic control,
this setup is quite normal , compool [ pentair ] makes a control for this and you should be able to get the plumbing diagrapham from there site.
steve
