Hayward Heater
Old 06-23-08, 04:10 PM
Hayward Heater
I have a Hayward H1000 Propane heater on an aboveground pool (12'x28'x6'deep end) It has been running great for the last 4 or 5 years. I fired it up this past weekend & it started without a hitch brought the water from 72 degrees to 82 degrees no problem.The problem is when it reaches temperature & shuts off it will not re ignite. I replaced the igniter & wire,that did not fix it.If you unplug the power cord & let it set for just a couple of seconds & plug it back in, it fires up & runs until it reaches temp again. When I came home from work today the fan was running but no fire. Sorry if I seem rambling I'm just trying to add all the info I can think of.Propane tank level is at 50%. Door is closed safety switch is depressed.
Old 06-23-08, 04:23 PM
Change to previous post. Now it seems it will not ignite at all.
