Covering Pool
Old 07-07-08, 05:20 AM
Covering Pool
Hi,
We have an above ground Intex pool that came with a cover. Should I cover the pool when not in use? The only problem I have with covering it is that when we use the pool, the cover that came with it also touches the water and gets water on it. If I remove it then reinstall it, dirt goes into the pool. If I cover it, will that help keep my water at the recommended pH, Chlorine, and Alkalinity?
Thanks.
Old 07-07-08, 06:43 AM
todrut's Avatar
Covering the pool will help reduce chemical consumption and keep dirt out. However if you get more dirt on the cover by taking off and putting on I would leave it off. It's really your choice what works best for you...
Old 07-07-08, 07:44 AM
The cover may help maintain your chlorine but with your stabilizer running at 50ppm you should be fine. I'd leave the cover off. Too much of a pain to install and take off.
