Pressure Switch tube is clogged
Old 07-09-08, 01:44 PM
Unhappy Pressure Switch tube is clogged
I have a pressure switch installed that turns a water feature on and off. The switch is fine but it looks as if there was water in the tube leading from switch to the actuator.
Any suggestions on what to best use to get water out would be welcome.
Addtl. info: tube is about 60 feet long and underground, so not easy to simply replace.
Thanks for your help!
Old 07-17-08, 01:47 PM
Are you talking about a pneumatic switch? If there's water in the line, I would blow it out with a compressor.
