Spa Insulation Removal help
Old 07-18-08, 08:41 AM
I have a leak and am zeroing in on the problem. Is there any better way to remove the foam insulation around pipes and fittings without chipping away with a knife or razor? Anything to use that could safely melt away the foam?
Old 07-18-08, 04:23 PM
todrut's Avatar
depends on the area you are working on, I've used a sawzall but got to be careful not to cut a pipe. Also a drywall saw helps.
Old 07-18-08, 04:28 PM
Gunguy45's Avatar
Super Moderator
I know it sounds stupid..and it depends on the age and type of the insulation, but I've used a bread knife and a pro quality ice cream scoop. Hey, it worked!
