Go Back  DoItYourself.com Community Forums > Garden and Outdoor Center > Pools, Spas and Hot Tubs
Reload this Page >
Repairing a stain in a Pebble Sheen surface?
Old 01-05-09, 05:11 PM
We have a pool with a Pebble Tec "Pebble Sheen" surface. The color of the surface is "Blue Granite". I asked my wife to add some chlorine one day, and not knowing any better, she tossed the chlorine tablets directly into the pool. They settled on the bottom and left a dark, almost black stain on the Pebble Sheen where the chlorine must have had some chemical reaction with the surfacing. Does anyone have any suggestions or ideas as to how this can be repaired, either with or without draining the pool?
Thanks for any and all advice!
Old 01-12-09, 06:32 AM
K
That certainly leaves a nasty stain. If you want to drain the pool you can use a light masonary grinder to buff the stain out with a light grit diamond grinding pad. If you cannot drain the pool you can try taking a cheap garden sprayer and adding a 50/50 mix of water and muriatic acid and spray then brush the stain under water. Just make sure you add the acid to the water not the water to the acid.
