Gibraltar pool skimmer
Old 03-20-09, 04:12 PM
The skimmer mounted on the wall of our above ground pool is cracked. I think I can unscrew it from the pipe, but I can't get it loose from the wall. I have removed the bolts that were bolted through. I am sure it is just a sealant that is holding it but wanted to be sure before I did any permanent damage. Sometimes I am not too gentle. Any help will be appreciated !!!
Old 04-05-09, 06:16 AM
try scoring around where the skimmer meets the pool shell with a razor knife, most use high grade silicone to help seal up the connection.
