Pool opening this weekend what should I see
Received 0 Votes
This weekend I am removing the cover form my above ground pool. This is the first uncovering for me and I do not know what to do to get the pool ready for use.
Any advice would be apreciated.
Dan NJ
Beer 4U2
Dan NJ
Beer 4U2
what you see depends on if it was closed properly. Hopefully your water is clear and mostly dirt free. Connect your equipment and fill pool to proper level and start filtering. You will want to shock pool and start tabs, adjust chemicals then vac pool. Good luck..
