swimming pool caulking
Old 06-17-09, 10:31 AM
K
Smile swimming pool caulking
There is a space between the cooping and the cement that has a gray bead of "caulking" in it. This has aged and needs to be replaced. Does anyone know where to get this "caulking" and if I need to scrape old out first. This seems to be letting water in under the cooping.
Thanks
Old 06-17-09, 01:57 PM
todrut's Avatar
if the old is below grade you wont need to remove, it will take the place of backer rod. there are a few self leveling expansion joint sealants out there. Vulkem makes a good one. Google it and you can compare.
