Hayward 4000 impeller STUCK!
Received 0 Votes
Need to replace motor bearings and I can't get the impeller off. I've got the shaft held with a wrench, but no amount of force can get the impeller off, turning per hayward manual, counter clockwise. Any tricks or suggestions? Thanks.
Received 0 Votes
You do know that it's a left-hand thread, right? Most of them are, at least. You can always tell by which way the motor runs. They're always threaded in such a way that the normal operation of the motor would tighten the impeller on the shaft.
(Sorry if you knew that already. Just thought it would be worth mentioning before you break a motor shaft.)
