Outdoor shower
Old 03-22-10, 07:31 AM
riggstad's Avatar
Outdoor shower
I'm designing an outdoor shower and want to install in about 2 weeks.
It will sit on the topside of the house. Our property is graded downward about 3 degrees from left to right when looking at the front of the house. 3 degrees is a lot
The shower needs to be on the high side because that's where entry to the house will be.
My question is, without adding a drain, is there anything I can, or should do about diverting the waste water away from the house?
I plan on installing a paver base (on top of a good 8 inch base of stone and sand). It will be directly off the back corner of the house.
Is digging a trench and burying, say, a 4" pipe leading out to the middle of the back yard going to do anything without actually accepting the direct stream of waste into it via a drain?
Old 03-22-10, 07:42 AM
todrut's Avatar
Without seeingand being able to evaluate the location, it is hard to give any advice other than there needs to be a drain or proper run off to keep from showering in a puddle.
