Leisure Bay Celebrity Hilo 2005 SMART control panel, how to?
Attached is a pic of the panel. I just got this hot tub (free!) and it works great. BUT, I believe the control panel probably does more than the obvious in the right button push combos. The only manual I can find online is 2007 and it has a different control panel. Does anyone know how to work this panel correctly?
sorry, does pretty much what is obvious
Jets=booster jets for when in tub
Turbo air=bubbles
light=light
Accutemp=temp setting for water
Heat=light when heat is on
just a basic control...
Turbo air=bubbles
light=light
lol I was hoping it did more, I found other things online where there were combinations hit that gave other orders, like the temp up and then hitting the light button would change a mode from economy to normal or something. Right now jets and/or air stay on for 20 minutes then go off automatically, which is fine, but am I correct in that the filter is only filtering when the air or jets are on? It does come on automatically and circulate for a minute or so and then stops again throughout the day, which makes me think that one or the other needs to be on for the filter to filter. The bottommost part of the tub has one jet that is continually functioning but I think its just for heating the water?
The filter is a waterway pressurized one and I can find no instructions for that either, it took forever for us to figure out how to open it. It has a bromine thing in the center.
Thanks!
Thanks!
What is coming on and off should be the call for heat whick is circulating the tub. The one continuosly should be filtering the water to keep it clean and sanitized. Make sure to clean filter regularly, soaking in a large bucket with hot water and a couple tablespoons of cascade dishwasher detergent overnight will keep the oils from building up and causing a new one. Rinse well before returning to tub.
