above ground pool deck help
Old 05-04-10, 11:30 AM
hi going to biuld a 4 foot deck around my above ground pool
pool is 15ft x 48
wht i need to know is trapezoidal floor-joist frames--4-sided frames with two parallel sides and two sides that angle toward each other can any one help me with meauserents for this
the poles are 3ft apart and i want to go out 4ft all help is needed thanks
blackie
Old 05-27-10, 11:22 AM
Not sure what u mean by trapezoid joist hangers. Can you insert a picture? Perhaps pathagorean therom will help u? I have a deck built around my 24' pool that is 5 ft wide. I put post at all 16 corners and 16 more 5' parallel to each corner.
Old 05-28-10, 06:21 AM
deck
some say you have to build each part one by one and put them together I get that but they say you have to have the end at the pool smaller and then wider at the other end and then each part the same and put together as you go
so it will make it round like the pool i'm not sure what size to cut the fisrt section i hope that is the way to explain it
thanks blackie
