Hayward H150
Old 07-04-10, 12:56 PM
Hayward H150
Just replaced heat exchanger. Pilot light will lite but nothing else happens. After i got the pilot light lit turned on switch on adjusted thermostat till i heard it click and the burner didn't kick on. The heater is propane. Any suggestions where to start. It worked before i changed the heat exchanger. Put meter on two wires coming from pilot light reading from 307 to 291. Whats my next step. Thanks
Old 07-04-10, 06:40 PM
todrut's Avatar
check the safety loop for loose wires
Old 07-20-10, 08:21 PM
I know it worked before, but try bypassing the pressure switch. By the way, I am thinking of replacing my nat gas H150 heat exchanger. How difficult was it? How long did it take?
Old 07-20-10, 09:21 PM
todrut's Avatar
use your search, there is a post walking you through it.
Old 07-22-10, 07:59 AM
Did the search but couldn't find anything. I still have the manual which gives the instructions. I was just wondering how difficult it was.
Old 07-22-10, 03:03 PM
todrut's Avatar
In my opinion it is relatively easy. Those less mechanical might find it harder.
