Pool 12 volt light
Old 10-23-10, 04:55 PM
Pool 12 volt light
I have a 12 volt Color Logic Hayward pool light. As stated it is 12 volt.
I also have a Fiberstars 110 volt controller that will turn it on and off. Can I use this controller to operate the 12 volt light.
I have a 12 volt transformer. Should I place the transformer after the controller or before the controller?
thanks
Old 11-03-10, 06:02 PM
If you put that 120v on the 12v, it will light, one time and very bright.
Use the transformer. Make sure the VA rating is sufficient to carry the load for the light. Also make sure the light is 12VAC not DC. Or maybe the light has the option of ac/dc.
If it's a dc light,. then you will need a 14VAC transformer and a bridge rectifier. The bridge converts ac to dc and will consume (drop) a volt or 2 making the dc. You can get one at radio shack and then look up on the net to see how to wire it. It's easy.
Also, ALWAYS fuse a new load in the tub for that extra component. At Radio Shack, buy a fuse holder and 1A or 2A fuse (again, check what current the light draws and add an amp for a fuse to protect wiring to that load).
Old 11-03-10, 06:13 PM
The light is 12 volt AC. The controller is 115 volt AC. What I needed to know is can
I Put a a/c transformer on the wire before it goes to the light and reduce the voltage from 115 AC to 12 Volt AC?
All this other stuff you speak of is totally greek to me.
Old 11-08-10, 02:33 PM
You sure can. I would still try and fuse the circuit between your controller and the transformer. If the transformer ever shorted, got wet, or somehow malfunctioned, you would probably be replacing the controller. Just a little protective thought.
Old 11-08-10, 04:49 PM
Thanks for the help. I will add the fuze for securigty
Tom
