Go Back  DoItYourself.com Community Forums > Garden and Outdoor Center > Pools, Spas and Hot Tubs
Reload this Page >
T104R DPST Dial Time switch - clock turns but no power to motor
Old 02-19-12, 10:35 AM
D
Question T104R DPST Dial Time switch - clock turns but no power to motor
Hi,
I have a Intermatic T104R DPST dial time switch connected to my pool pump. Everything has been working fine so far. Yesterday, the pool pump stopped running. I have verified, using a multimeter, that
- Breakers have not tripped (I flipped them on and off)
- Line voltage is reaching the timer (I get 110V between terminals 1 or 3 and ground)
- Clock is running
- Pool pump does not run even with manual override
- I get no voltage at the terminals on the motor
- I get no voltage between the terminals 2 and 4 (Load terminals) at the timer
I am guessing the timer has failed and needs to be replaced.
- Are there any further steps I can take to diagnose/fix the problem?
- If replacing, am I better of replacing with a digital timer? Are there such things available for this application? I would appreciate any recommendations.
Thank you for your help.
Old 02-19-12, 12:35 PM
D
"Line voltage is reaching the timer (I get 110V between terminals 1 or 3 and ground)"
This is not a relevant test.
Do you get 220v between 1 and 3?
Old 02-19-12, 03:53 PM
D
Thanks for your response.
Yes, I am getting 220V between 1 and 3.
BTW, why is getting 110V between 1 or 3 and ground relevant?
Deepak
Old 03-11-12, 02:48 PM
W
Just a long shot, but is your dial push back?..You know how you can pull it out to adjust the time, maybe its has moved out.
