Sundance hot tub question
Old 05-09-12, 08:43 AM
B
I have a 2001 Sundance Marin Hottub. The 2 speed motor runs on both speeds but does not circulate water throught the jets. It has not been recently filled and pump appears to be primed. When this first began if i restarted the pump a couple times it would work normally. Can this be fixed by replacing the pump on the wet end which is much cheaper than the service mans suggestion of replacing the entire motor/pump assembly.
Old 05-09-12, 08:57 AM
todrut's Avatar
sounds like the impellar is either clogged or broken.
Old 05-09-12, 09:00 AM
B
Thanks, I am going to drain it and take the pump apart tonight. I suspected an impellar issue because there isnt much else in there but wanted someone else to confirm. If its more it will be out of service until the new pump arrives and momma luvs her tub!!!
