jacuzzi gardent tub jet removal
Old 05-09-12, 09:50 AM
I need to remove the jets on my jacuzzi garden tub and replace the trim rings. I have forgotten the technique. I think it was turn clockwise or counter clockwise and pull but would like some advice before I attempt the wrong think and break one. Any advice appreciated.
Old 05-09-12, 11:25 AM
It depends on the type of jets. Some have a trim ring that unscrews (lefty loosey, counter-clockwise) while others snap in place and you just pry under the edge.
Old 05-09-12, 11:36 AM
these pry off. My problem is i am not sure how to remove the jets, they need to be taken out and cleaned or replaced.
Old 05-09-12, 12:11 PM
Mine, after the trim bezel is removed have a ring that screws in to apply pressure to the jet eye/ball. The ring has a couple notches so you can catch it with a flat blade screw driver to unscrew. It's plastic so you have to be careful if it's screwed in tight or minerals & scum have it locked in place.
