Hot tub
Old 05-11-12, 04:50 PM
Hot tub
I have a 2004 great lakes hot tub calls for a 50 amp 240 volts four wire can this spa be wired as 110 volt friends said they wired there spas for 110 but I not sure what to believe have no more room in breaker box for another 240 line
Old 05-11-12, 09:26 PM
D
My car does 0 to 60 in about 5 seconds....doesn't everyone's"?
According to the 2004 manual I have, no. They're all 240v only.
"Use a 50 amp 240 volt 4-wire GFCI circuit breaker for all Great Lakes Hot Tubs 240 volt models."
though, I may be missing a manual for that year, and there may be other models that are 110v or convertible. There should be electrical rating labels somewhere that clarify if it's possible or not.
Old 05-11-12, 10:35 PM
ray2047's Avatar
In that case probably the cheapest, simplest solution is to add a subpanel next to your main panel.
Old 05-12-12, 04:48 AM
ThankS for the advise will check into a sub panel box.
Old 05-12-12, 06:57 AM
D
Or switch out full size breakers for wafer breakers.
