pool light...what should I replace ?
Every time I turned the pool light on the circuit breaker would trip. I took out the light from under water and opened it. There was water inside the light's cavity- which is what caused the breaker to trip. The bulb inside is a regular spot light bulb. The gasket around the outside glass seems ok but I am sure water went through it. Can I purchase the rubber gasket separately, or does it come with the glass as one piece ? Thanks.
